Can I create a link on my custom toolbar to a pdf or a different program? So the user can click on it in and it will open the other program or link?
Bryon
Found this.
Starts an external application.
Syntax
LAUNCH "app" "cmd"
app (string) Filename and path to the external application to
be started.
cmd (string) Parameters to be passed to the application on
start-up.
If the application starts, the LAUNCH command returns the application’s process
ID. If the application fails to start, the LAUNCH command returns zero.
Example
# Open Macro-Logfile with Notepad
MACRO Show_Logfile
LAUNCH "C:\WINDOWS\notepad.exe" "C:\ ... \macro.log"
END MACRO
This is my macro just does not seem to work
Macro guide_pdf
LAUNCH "C:\Program Files\Adobe\Acrobat DC\Acrobat\Acrobat.exe" "Z:\network drive\Guide\arbortext_guide.pdf" .
Bryon
End Macro
