Isoengine73.exe and 2K12
marias(customer
Good morning all,
A quick questions. Is PTC --> Arbortext IsoView 7.3 --> Isoengine73.exe  Compatible with Windows Server 2012 R2 ? (With IE11)
The application came bundled with an IETP Software. The IETP Software works fine, and I am able to see the thumbnail of the illustration alright. Yet, when I click on the Thumbnail, the illustration does not open up and the Isoview Buttons do not work.
so:Is the bundled Isoview app compatible with Server 2K12 R2?
  • Are there any tricks to make it work? For example, I have already disabled pop-up blocker in IE11, Added the relevant web page to Compatibility Mode and  to the Security Tab --> Trusted Sites (with "enable protected mode" disabled)
  • I tried "compatibility mode" on the Isoengine73.exe  using XP SP3 and others
  • All of the above to no avail
Any tips or ideas ?
Many Thanks
Mariano
Hi Mariano,
Please find "Arbortext Software Compatibility Matrices" and other Arbortext IsoView 7.3 reference documents in attachment.
Many thanks Vladimir,
Since Microsoft Server 2012 R2 is not mentioned anywhere in the Software Compatibility Matrix, I assume then that it is not supported.
best regards,
Mariano
