Key mapping trouble
rschoen
Key mapping trouble
I'm debugging some of our tools, etc. in our switchover from Arbortext v5.3 for Unix to Arbortext v6.1 M010 for Windows. We have quite a few key mappings that I was hoping would not require any changes. The problem I'm encountering is that and any key combination of ALT plus a lowercase letter, e.g., ALT+c to insert a comment, does not work in the Windows version of Arbortext. If I key ALT+c Arbortext just beeps at me and does nothing. ALT plus a non-alphanumeric key, e.g., ALT+-, works just fine. Any thoughts on what could be causing this problem?
Rick
Rick,
I am having the same issue trying to map from the command line.
What I see when I look at the full key mapping for Epic is there are no ALT
commands mapped to a single letter. ALT is used either with the Control key
or by itself with all keys except alpha keys (a-z). L
Really strange because I don't see any restriction for this in the Epic Help
Center topic (help 9018). I tried this with Epic 6.1 M020 and also tried it,
without success, in Epic 5.4.
Lynn
Hi Rick
I suspect you won't be able to map Alt-X key codes under Windows. These are used by the operating system as accelerator keys for the menu system in the Windows GUI. Eg. Alt-F is a common shortcut to bring up the "File" menu.
This means Arbortext cannot remap that key, as it is under the control of Windows.
// Gareth Oakes
// Chief Architect, GPSL
// www.gpsl.co
rschoen
(To:rschoen)
Lynn,
Thanks for backing me up. I was beginning to think that I was missing something obvious.
Rick
rschoen
(To:rschoen)
Gareth,
Shoot! I understand why this would be the case but I'm not happy about it. I guess I'll have to change those keymappings.
Rick
