Me Again: Error Message
Hello Again,
I get the following error message when I try to preview the document.
[A30040] ERROR: Infinite loop detected. Please check FOSI for recursive savetext/usetext combinations.
What I've done is set up my XML document and the style sheet then I close it. I open the XML document in a text editor and change the starting tag to chapter. When I open the document in Arbortext and insert a TOC, then try to preview, I get the error message. According to Arbortext, TOC is still a legal tag after title. When I delete the TOC tag, the error message goes away.
Curiouser and curiouser.
Ginger
