Multiple text entities search
jchang-2
To Whom It May Concern:
Here is my question.  I'd like to search for several text entities in my ACL script.  For example, searching for &MP00002; and &M1229015a;.  Below is what I did.
/* It works when there is one entity only. */
find -m -q -nowrap '&MP00002;';
/* None of the following tests works*/
find -m -q -e -nowrap '&MP00002;|&M1229015a;';
find -m -q -e -nowrap /&MP00002;|&M1229015a;/;
May I know what is the acceptable regular expression for it?
Best Regards,
Jing
rdiaz
(To:jchang-2)
Hi Jing,
I don't believe the regular expression flag -e allows for searching for multiple values.
You may have more luck trying something like this by setting up a slightly more complex statement performing two separate find commands and returning the first one found.
If you need help with that, the customizers on here are fantastic resources!
jchang-2
(To:rdiaz)
Hello Rafael,
Thank you very much for your great help.  Yes, the regular expression -e wouldn't search for multiple values.  I ended with the following command plus a group of text entities saved in an array for comparison to solve the problem.
find -m -e -q -nowrap /&[M][P]?[0-9]+[a]?;/
Best Regards,
Jing
