My PTC Arbortext Editor 7.0 CD includes the Publishing Engine 7.0
mleboulluec
My question is:
Can the publishing engine be installed on each licensed computer locally, or does it have to be on a local server? If not a local server, how do I set up a network server for the publishing engine? Who would I have to contact to set up a network server? PTC technical support perhaps?
Thank you - Mike
Directed to the proper documents allowing my company to set up the Publishing Engine.
Refer to the following manuals available on the PTC website:
e3admin.pdf
e3install.pdf
e3admin.pdf
e3install.pdf
