In Arbortext Editor 6.1 when new tag insert in document it will open a window/dialog box for some user input.
The same needs to be done using macro, When I record this event the command in the macro code is only for insert tag but there is no window/dialog box events and user inputs, button click event in macro code.
How can we handle or record window dialog box event in macro.
Thanks in advance.
