Problem with a Turbo Styler sheet
Hello, We currently have some trouble with one XSL stylesheet. The sheet hasn't been modified in any way since it was last working (the file date is 09/02/2005) but when I open any XML document I get the following error : [A30223] Could not load stylesheet 'C:\dtd\doctypes\presse\article\article.xsl' - _stysht::load_xslt_ss failed When the XML document is loaded in Epic, if I try to select the stylesheet (Format/Turbo styler) I get this error message : "[A30121 Stylesheet article.fos cannot be edited with turbo styler" The reference to article.fos is a mystery to me, as I selected article.xsl. For reference, we are using Epic 4.3, build JUN-1218. Any idea on how to fix this, or any things to check welcome. Thanks and regards Christophe Lefebvre LexisNexis France
