Problem with a Turbo Styler sheet
ChristopheLefeb
2-Explorer
Hello, We currently have some trouble with one XSL stylesheet. The sheet hasn't been modified in any way since it was last working (the file date is 09/02/2005) but when I open any XML document I get the following error : [A30223] Could not load stylesheet 'C:\dtd\doctypes\presse\article\article.xsl' - _stysht::load_xslt_ss failed When the XML document is loaded in Epic, if I try to select the stylesheet (Format/Turbo styler) I get this error message : "[A30121 Stylesheet article.fos cannot be edited with turbo styler" The reference to article.fos is a mystery to me, as I selected article.xsl. For reference, we are using Epic 4.3, build JUN-1218. Any idea on how to fix this, or any things to check welcome. Thanks and regards Christophe Lefebvre LexisNexis France
I don't seem to be able to edit my own post. Anyway, just something I forgot. Before getting the [A30223] error message in the Epic Editor Messages window, I get a dialog box with that error message : [A19397 Error opening XSL stylesheet "C:\dtd\doctypes\presse\article\article.xsl"
I solved the problem (not sure how though). I reinstalled Epic and corrected the APTCATPATH system variable (there was a %%D instead of the %D in it) and it works now.
