Problem with using mouseclick in macro to select callouts on illustration
  • April 26, 2013
  • 1104 views
I'm trying to get a macro to select callouts but get errors
This is a little macro that illustrates my problem
macro test_me
define me as MouseEvent
define el as element
me = Wait MouseClick
Select at me.ptmm.x me.ptmm.y Direct
el = ActiveDoc.FirstSelectedElement
MESSAGE el.type
end macro
When run this macro just displays the selected element type - "Line" or "Bezier" etc.
But if you click on a callout it gives the following error message:
Macro: Error in expression syntax.
"MESSAGE el.type"
Anyone have any advice?
    Best answer by thendricks
    Try the following. Looks like the direct comment is selecting within the callout possibly. Remove that and the issue seems to be resolved.
    macro test_me
    MESSAGE el.type
    end macro
    macro test_me
    MESSAGE el.type
    end macro
    TimSharp1-VisitorAuthor
    Thanks Trevor
    Never thought to do that, it works a treat so hopefully I can finish my macro now.
