We are in the process of switching our style sheet from fosi to APP. Currently, we use Arbortext Print Composer on each desktop for publishing. In testing the published output, we are finding that while it is publishing you cannot do anything as the system always brings the editor screen to the front. Is there a way around this??
Bryon
I don't know of a way around this, besides from using Publishing Engine instead of Print Composer.
