QR Tags in Arbortext?
mramshaw
We want to start inserting QR tags in our paper documents to provide an online link to them. Do we need to mess around with inserting a PNG file into the document or does anyone know if Arbortext has specialized support for QR tags?
Hi Mike,
There is nothing specifically in Arbortext for QR codes but you could of course do them as images. If your workflow requires something more dynamic, it would be fairly simple to embed a QR Code generator (eg. a Java library) into Arbortext to build the QR code images at run time.
Cheers,
Gareth
Thanks for the info, I am behind the times and just recently heard of these things. Good to know there are java libraries to generate them as that is what we will probably have to do.
