Hi all, Is there a keyboard shortcut to toggle between full tags and no tags ?
FYI, you can create your own keymappings with the map command, which can be entered at the Edit window command line or incorporated into Arbortext Editor startup scripts. For more information, search the Help Center for map, unmap, and show keymap commands.
Hi Nikita,
The default for this is:
| * Control+Shift+L | ToggleTagDisplay |
If you want, you can type the following on the command line in the Editor:
show fullkeymap
This will display all current keyboard shortcuts, and the very long list is searchable with a CTRL+F
Thanks a bunch Rafael !
Nikita, if Rafael's response provided the correct solution, then could you indicate so by selecting "Correct Answer" in his response.
This will help those of us in the community recognize that a query has been given a correct answer.
Some community members looking for answers may skip over threads that appear to match their questions, but are not marked as answered.
