Setting a context specific attribute to read-only ?
tracey.orso
Hello everyone,
Just wondering if anyone know how to set an attribute to read-only -
in a specific context.
In the .dcf I can set>
<attributeoption attribute="attname" dialoghidden="no" readonly="yes"/">
But I need to set it at a specific level. The same @attname at the
root level needs to be editable.
thanks,
Tracey
Offhand, I'd say your best bet is to intercept the opening of the
Modify Attributes dialog using a "create" window callback. This will
give you the opportunity to examine the current element and make the
relevant attribute(s) read-only by disabling the corresponding XUI
controls.
-Brandon 🙂
