combobox value not getting updated on a Windows-7 machine
Hello adepters,
I have a weird problem that I experienced on a Windows-7 machine, I ran the same code on Windows-vista and it works.
I have a comobox with listitems, if I tab over the combobox and select the item by arrows without hitting enter the value of the comobobox doesn't get updated with the selected item. If I hit enter after selecting the item or use the mouse, the value of the combobox gets updated. On windows vista, the value gets updated whether I hit enter or not.
Did anybody experienced a similar problem?
Below is the XUI box:
<window title="Single" question"=" orient="vertical" modal="false" align="end">
<script type="application/x-javascript" ev:event="WindowLoad">
var dialog = Application.event.target;
var xuiDoc = dialog.dialogView.document;
</script>
<textbox width="200" resize="none"><value id="nameValue"></value></textbox>
<combobox id="typeCombo" type="dropdownlist" width="120" resize="none">
<listitem label="string"/">
<listitem label="date"/">
</combobox>
<button label="type" value"=" type="accept">
<script type="application/x-javascript" ev:event="domactivate">
print(xuiDoc.getElementById("typeCombo").getAttribute("value"));
dialog.close();
</script>
</button>
</window>
-Samah
</script>
</combobox>
dialog.close();
</script>
</button>
</window>
-Samah
