Setting font and size of Generated Text in the Styler
Partner
I want to be able to set a particular font and size for the category Generated Text in the styler.  I don't see any font settings inside the window when editing the generated text.  All I'm able to do is specifying Normal, Bold, Italic and so on.
Thanks for your precious help and advices.
SimonTaylor
(To:Partner)
Hi
An easy way to do this is to edit the generated text, add a new User Formatting Element (UFE) around the text you want to style and then style that in the Styler interface as you would any other element.
Simon
You can do that from Edit>Modify Font Menu.
Partner
(To:Vinod_Pimple)
I don't see Modifiy from the edit menu, only have Modifiy Attributes... and Modify Processing Instruction which is grayed out.  Please provide the complete steps.
Thanks.
If you highlight your text then choose format, font it will wrap your text in a font wrapper.
Bryon
Hello @Partner
It looks like you have some responses on your topic. If it helped to answer your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
SimonTaylor
(To:Partner)
Hi
Simon
