I've been using Arbortext 7.1 to author documents that use the 40051-2C XML architecture.
The latest version of the configuration files are acting strangely. Apparently, you can insert any tag anywhere. That is, when I click Insert > Markup for any tag, I get a big list of tags that starts with a.statement and ends with zip.
In some ways, this looks like a good thing, but it will probably cause problems somewhere. I'm wondering if this was intentional, accidental, or maybe a problem at my end. I've done a WinMerge comparison of the last two versions of the config files and can't find any clue to what's going on.
I access the config files from https://pubsweb.redstone.army.mil/DTD-FOSI/Webpages-60/ALLDTDs-AMCOM.html. It's the 40051C 6.0 link at the top that's dated 11/11/18.
Bob
It sounds like the document has context rules turned off. Select Tools>Context Rules to see if context rules are on or off. If the document is out of context, context rules are automatically turned off. Select Tools>Check Completeness to find context errors.
Hope this helps!
Suzanne Napoleon
FOSIexpert.com
"WYSIWYG is last-century technology"
Hope this helps!
Suzanne Napoleon
FOSIexpert.com
That was exactly the problem. The updated architecture doesn't like some of my customizations. Thanks for your help.
