Strange lines when Opening AutoCAD file
khoward
7-Bedrock
Hi Gang,
Have an annoying problem when opening an AutoCAD drawing in IsoDraw 7.4. When I open the drawing I notice there are several lines shooting out in all different directions. When I activate the line I will notice one is snapped to another line, the other end is just floating out in space. I can select the endpoint of the line in IsoDraw and connect it to the point where it belongs with no problem. My question is why is it doing this action. I look at the AutoCAD drawing and the lines are in the correct location in the initial drawing. Any ideas on what might be causing this issue and how to correct the problem?
0 REPLIES 0
