TOC formatting
SindyYoung
2-Explorer
TOC formatting
Good Morning Everyone,
I am using Epic Editor 5.3M60 and a fosi.
I have subparas where the title is optional .
The problem is that these subparas report to the toc.
It is driving me nuts. I can't figure out how to tell the fosi, that if title doesn't follow the para tag, do not report to the toc.
Any suggestions.
[cid:image001.png@01CAB540.8D6A0370]
[cid:image002.png@01CAB540.8D6A0370]
Sindy Young
AWACS Tools and Technology Team,
(253) 657-6964
Kent, WA 98032
10 REPLIES 10
We have a similar need. Call this ACL in an <att> rule.
# get_next_oid_name
# From a FOSI call, return the name of the next element, or nothing
# if no sibling element.
# Originally coded for use with graphic e-i-c to test for following
# graphic when deciding whether to start next page after graphic.
function get_next_oid_name(window, oid)
return oid_name(oid_next(oid));
Can't do this in FOSI without the ACL.
Steve Thompson
+1(316)977-0515
Sindy,
Here is the actual data from my FOSI that does what you want (I think):
Set up a style set for "toc" and one for "no.toc"
<charsubset charsubsetid="subpara.title.toc">
<hyphen inherit="0" hyph="1">
<quadding inherit="0" quad="left">
<highlt scoring="1" scorewt="1pt" scorechr="_" scorespc="1">
<presp minimum="5pt" nominal="6pt" maximum="7pt" condit="discard" priority="med">
<keeps keep="1" next="1">
<savetext textid="subparatitle.appear.tdv" conrule="\yes\">
<usetext source="labelstr.tdv," 0.3em&quot;=" placemnt="before">
<subchars>
<textbrk startln="0" endln="0">
</subchars>
</usetext>
<usetext source="\.\," 1em&quot;=" placemnt="after">
<subchars>
<highlt scoring="0">
</subchars>
</usetext>
<savetext textid="pagenum.tdv" conrule="pgprefix.tdv," pagect.tdv[bo]&quot;=">
<savetext textid="voltocmatter.tiv" conrule="&lt;newline">, <toc-entry.fmt>, 1.5em, labelstr.tdv, @6.5em, #CONTENT, sssn.tdv, tocfill, </toc-entry.fmt>, <tocnumx>, pagenum.tdv, </tocnumx>, </newline>" append="1">
<savetext textid="tocmatter.tiv" conrule="&lt;newline">, <toc-entry.fmt>, 1.5em, labelstr.tdv, @6.5em, #CONTENT, sssn.tdv, tocfill, </toc-entry.fmt>, <tocnumx>, pagenum.tdv, </tocnumx>, </newline>" append="1">
</charsubset>
<charsubset charsubsetid="subpara.title.no.toc">
<hyphen inherit="0" hyph="0">
<subchars>
</subchars>
</usetext>
<subchars>
</subchars>
</usetext>
</charsubset>
Then, in the e-i-c's for the specific tags (I want a toc entry for subpara2, but not for subpara3) call the approprate style set:
<e-i-c gi="title" context="subpara2">
<charlist envname="titleenv" charsubsetref="subpara.title.toc">
<textbrk startln="1">
</charlist>
</e-i-c>
<e-i-c gi="title" context="subpara3">
<charlist envname="titleenv" charsubsetref="subpara.title.no.toc">
</charlist>
</e-i-c>
<e-i-c gi="para" context="subpara2">
<charlist>
<indent inherit="0">
<quadding inherit="0">
<textbrk startln="0" endln="1">
</charlist>
<att>
<specval attname="subparatitle.appear.tdv" attloc="#FOSI" attval="#EQ#\yes\">
<charsubset>
<usetext source="process.symbol.tdv" placemnt="before">
</usetext>
</charsubset>
</att>
<att>
<specval attname="subparatitle.appear.tdv" attloc="#FOSI" attval="#EQ#\no\">
<charsubset>
<textbrk startln="1" endln="1">
<usetext source="labelstr.tdv," 8pt&quot;=" placemnt="before">
<subchars>
</subchars>
</usetext>
</usetext>
</charsubset>
</att>
<att>
<fillval attname="applicref" attloc="subpara2" fillcat="usetext" fillchar="source">
<charsubset>
<usetext>
<subchars>
</subchars>
</usetext>
</charsubset>
</att>
&inschg;
&delchg;
</e-i-c>
<e-i-c gi="para" context="subpara3">
<charlist>
</charlist>
<att>
<charsubset>
</usetext>
</charsubset>
</att>
<att>
<charsubset>
<subchars>
</subchars>
</usetext>
</usetext>
</charsubset>
</att>
<att>
<fillval attname="applicref" attloc="subpara3" fillcat="usetext" fillchar="source">
<charsubset>
<usetext>
<subchars>
</subchars>
</usetext>
</charsubset>
</att>
&inschg;
&delchg;
</e-i-c>
HTH,
-Andy
\ / Andy Esslinger LM Aero Tech Order Data
_____-/\-_____ (817) 279-0442 1 Lockheed Blvd, Mail Zone 4285
\_\/_/ (817) 777-3047 Fort Worth, TX 76108
I think what you need is #FOSI. I just added an example, title-exists-yn.pdf, to my web site at
www.FOSIexpert.com
Can you send the e-i-c for subpara2? If those are showing up in your TOC
even when they do not have a title as a child, that's the e-i-c that is the
most likely suspect. Typically (someone correct me if I'm wrong), that is
not how it's done. Typically, the TOC is updated on the title element in
context of subpara2 (which is shown in the code Andy submitted ... well, his
application's version of subpara2).
On Wed, Feb 24, 2010 at 11:00 AM, Young, Sindy R
> It is driving me nuts. I can’t figure out how to tell the fosi, that if
> title doesn’t follow the para tag, do not report to the toc.
> Any suggestions.
> Sindy Young
> (253) 657-6964
> Kent, WA 98032
I'm with Paul, and apologize for earlier post. I read your words without looking at the graphic.
The TITLE does not follow the SUBPARA1, it is its child. My ACL is specifically for checking a following element.
My bad,
Steve Thompson
+1(316)977-0515
Paul,
Here is the e-i-c for the subpara2 and the title.
<e-i-c gi="subpara2" occur="all">
<charlist>
<quadding quad="left" lastquad="lleft">
<presp minimum="6pt" nominal="6pt" maximum="6pt">
<postsp minimum="6pt" nominal="6pt" maximum="6pt">
<reset resetlist="sp3ct" step1ct&quot;=">
<savetext textid="sp2str" conrule="sp2ct">
<savetext textid="subpara2label" conrule="#CONTENT(label)" append="0">
</charlist>
<att>
<fillval attname="label" attloc="subpara2" fillcat="savetext"&lt;br"/>fillchar="conrule">
<charsubset>
<savetext textid="subpara2label"></charsubset>
</att>
<att>
<specval attname="label" attloc="subpara2" attval="#ANY">
<fillval attname="id" attloc="subpara2" fillcat="savetext"&lt;br"/>fillchar="textid">
<charsubset>
<usetext source="subpara2label,1em" placemnt="before">
<subchars>
<highlt fontclr="blue"></subchars>
</usetext>
<savetext conrule="\Paragraph" \,subpara2label&quot;=">
<savetext textid="toc.app"&lt;br"/>conrule="<subpara2label.fmt>,#CONTENT(label),</subpara2label.fmt>"
placemnt="before" append="1"></charsubset>
</att>
<att>
<specval attname="id" attloc="subpara2" attval="#NONE">
<charsubset>
<subchars>
</usetext>
<savetext conrule="subpara2label">
</att>
<att>
<specval attname="label" attloc="subpara2" attval="#NONE">
<charsubset>
<enumerat increm="1" enumid="sp2ct">
<usetext source="chapstr,\.\,para0str,\.\,sp1str,\.\,sp2str,1em"&lt;br"/>placemnt="before">
<subchars>
<highlt scoring="0" fontclr="blue"></subchars>
</usetext>
<savetext textid="toc.app"&lt;br"/>conrule="<subpara2label.fmt>,chapstr,\.\,para0str,\.\,sp1str,\.\,sp2str,</subpara2label.fmt>"
</att>
<att>
<charsubset>
<savetext<br/>conrule="\Paragraph \,chapstr,\.\,para0str,\.\,sp1str,\.\,sp2str">
</charsubset>
</att>
</e-i-c>
<e-i-c gi="title" context="subpara2" *=" body&quot;=" occur="all">_id="f241">
<charlist inherit="0">
<highlt scoring="1" scorespc="1">
<usetext source="\.\,1em" placemnt="after">
<subchars>
<highlt scoring="0"></subchars>
</usetext>
</charlist>
<att>
<specval attname="inschlvl" attloc="para0" attval="#ANY">
<charsubset>
<highlt bckclr="yellow"></charsubset>
</att>
<att>
<specval attname="inschlvl" attloc="subpara1" attval="#ANY">
<charsubset>
</att>
<att>
<specval attname="inschlvl" attloc="subpara2" attval="#ANY">
<charsubset>
</att>
</e-i-c>
You might want to try the following...
On the subpara element, create two savetexts:
<savetext textid="toc-entry" conrule="" placement="before">
<savetext textid="toc-app" conrule="toc-entry" placement="after" append="1">
On the title element, put a savetext to create the TOC entry:
<savetext textid="toc-entry" conrule="&lt;toc-fmt">Title Text</toc-fmt>">
where <toc-fmt> is a pseudo-element that specifies the formatting for the TOC entry.
The save to the TOC will occur at the end of the subpara element processing. If <title> is missing, the second savetext on the subpara will append nothing to the TOC variable toc-app.
HTH,
David
David S. Taylor
Project Manager, Structured Information
Institute for Research in Construction
National Research Council Canada
Bldg. M-23A, Room 239
1200 Montreal Road, Ottawa, ON K1A 0R6
Sindy,
I've had a look at the e-i-cs you provided.
In the e-i-c for <subpara2> it appears you are using an attribute named 'label' to create the TOC entry. Is the content of this attribute the same text as appears in <title> or is it something else?
Unless the text for the TOC differs from the text entered in <title>, an attribute shouldn't be necessary. If they are different, putting this attribute on <title> would be a better idea.
On the <title> element, the savetext would then be either of the following:
<savetext textid="toc-entry" conrule="&lt;toc-fmt">#CONTENT</toc-fmt>"> for the <title> as entered
OR
<savetext textid="toc-entry" conrule="&lt;toc-fmt">#CONTENT(label)</toc-fmt>"> for the attribute text.
Cheers,
David
I am pretty sure this test:
will be found TRUE if the label attribute is present whether or not it
contains content. Is this attribute present but set ="? Can you try running
your output having deleted the attribute? Do you get the expected/desired
TOC output if you fill the attribute?
If this is the case, one path to happiness will be figuring out how to
detect whether the label attribute has content vs. is defined.
On Wed, Feb 24, 2010 at 1:25 PM, Taylor, David S. <
david.s.taylor@nrc-cnrc.gc.ca> wrote:
> Sindy,
> <savetext textid=""toc-entry"" conrule=""&lt;toc-fmt">#CONTENT</toc-fmt>"> for
> OR
> <savetext textid=""toc-entry"" conrule=""&lt;toc-fmt">#CONTENT(label)</toc-fmt>">
> Cheers,
> David
> *From:* Taylor, David S. [
> <savetext textid=""toc-app"" conrule=""toc-entry"" placement=""after"&lt;br"/>> append="1">
> <savetext textid=""toc-entry"" conrule=""&lt;toc-fmt">Title Text</toc-fmt>">
> where <toc-fmt> is a pseudo-element that specifies the...
I believe that using #NE#\\ instead of #ANY will work.
