I am getting an error when I try to register PE subprocess COM Server.
Can someone please tell me how to resolve this error?
Thanks.
1. Use case logger - "Open a Support Case": https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
2. Article - "Arbortext Publishing Engine Server Optimization Tips": https://www.ptc.com/en/support/article/CS53173
A reinstall should sort it, otherwise you may be able to register the PE COM server using regsvr32.exe.
In a command prompt window that is running as Administrator, you can navigate to the editor.exe in bin\x64 and do
editor -RegServer
You can also run the PE Configuration tool and it will ask you if you want to register editor as a COM server.
