Hello
Does anyoneknow how to turn off e3 composition permanently? I know it's possible to set it to off within the command line for the current session via "set e3composition=off", but cannot see this option within Tools > Preferences.
If it's turned on, the Print Preview Options are disabled which I do not want.
Andy
Hi Andy,
As Clay mentioned, you can change it in the preferences. Someone else also mentioned coding it. The best option to permanently turn it off is to put that coding in your %CUSTOM%\init folder in one of the ACL files (or create one if it one doesn't exist). That way, every time you start a session with Arbortext, you will have the services turned off. I know that "e3services" works in 5.3 and before. With 5.4 and above, you want to use "peservices" as the set option. They both do the same thing.
Hope this helps.
Bob
In Reply to Andy Leslie:
Hello
Andy
