What file can I modify to add options in the menu that appears when right click with the mouse
  • August 2, 2016
  • 2 replies
  • 1990 views
Hello!
I've been trying to find the file where I can add a new option in the menu that appears when the user right click in a Document opened in Arbortext Editor. By the way, what's the name of that menu or dialog? Does anybody knows?
In advance I appreciate so much all your help and shared knowledge!
Paulette
Best answer by ClayHelberg
Hi Paulette--
There are two ways you can do this:
1) If you have a custom version of custom/lib/editmenu.cf, you can modify the section labeled "EditPopup", and the changes will appear in all instances of the edit window context menu.
2) You can use the menu_add command in an ACL script file, with the menu called ":EditPopup", just as you would to modify a normal top-of-the-window menu.
Hope that helps.
--Clay
18-Opal
August 2, 2016
Hi Paulette--
Hope that helps.
--Clay
pzorrilla1-VisitorAuthor
Clay,
Thank you so much!!
The information you gave me about the custom/lib/editmenu.cf file helped me a lot! I understand now how the EditPopup option works XD
Also, I was looking for an option already implemented in the popup menu and the way it is being called. As always I appreciate so much your time and help.
Regards.
Paulette
