Anyone using .asm files in Isodraw? Are you using Work Group Manager?
  • May 8, 2015
  • 2 replies
  • 1929 views
We have installed Work Group Manager to integrate IsoDraw with PDMLink. I want to use .asm files, but I don't get that option when selecting from my workspace - only graphic types are listed. I could choose .pvz files, but I cannot guarantee that all the geometry is updated in the .pvz. How are others creating illustrations in IsoDraw from Creo data?
Best answer by tmenadue
If you plan to use Work Group Manager with Creo Illustrate or IsoDraw, and you have Creo Parametric data in PDMLink, you use .pvz files. What a world of difference not having to wait on the heavy asm/drw files to regenerate!
18-Opal
May 8, 2015
We convert the .asm file to jt then you can import it into IsoDraw.
Bryon
tmenadue1-VisitorAuthor
Interesting. I'll talk to our admin about that possibility. According to this https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS34712&art_lang=en&posno=1&q=open .asm in isodraw&source=search it looks like once you connect to Windchill, you lose the .asm functionality.
Trish
18-Opal
May 8, 2015
We use Solid edge for our assemblies then you can save a translated version out (JT or STEP or IGS). I would believe that if you use creo you might be able to bring in the asm files.
Bryon
tmenadue1-VisitorAuthorAnswer
