XPATH help
cleccese
XPATH help
<listitem><para>text
<randomlist>
<I am here<para>text</para></listitem>
<listitem><para>text</para></listitem>
</randomlist>
</para></listitem>
</randomlist>
I'm trying to test if the top randomList has listItemPrefix="pf01" and ignore it if it doesn't have the attribute set
This doesn't work, I thought it would take me to the first randomList ancestor of listitem parent
../ancestor::randomList[1][@listitemPrefix='pf01']
Thanks for any help!
7 REPLIES 7
Try: ../randomList/@listItemPrefix="pf01"
Trevor Hendricks<">mailto:->
Project Analyst -- Publication Systems
Technical Communications, MS: 078
Thank you, Trevor, that didn't work.
Hi Caroline,
Maybe ancestor::randomList[last()][@listitemPrefix='pf01']
The ancestors are listed in reverse order, so you want the
last one to get the outer one.
Richard
this works:
../ancestor::randomList[1][@listItemPrefix='pf01']
Wait, what? That's what I had originally, but now it's working for some reason.
Thanks, Richard, unfortunately didn't work. (There were two randomLists, easy to miss)
berard
(To:cleccese)
How about:
./ancestor::randomlist[@listItemPrefix="pf01" and not(ancestor::randomlist)]
So that would be looking for an ancestor that has the prefix, but also is
not a child of other randomlists?
On Wed, Mar 26, 2014 at 11:43 AM, Hendricks Trevor <
> *Trevor Hendricks* <->
> *m*: 920-226-2116
> *p*: 920-457-4441; ext. 73571
> *f*: 920-803-3939
> *e*: -
> *Experience gracious living with **Kohler
> Math problems?? Call 1-800-10x(24+13)-(64-8y)/2+36x-17.
> *From:* Caroline Leccese [
> <randomlist>
> <listitem>I am here<para>text</para></listitem>
> </randomlist>
> </para></listitem>
> </randomlist>
> ignore it ...
Hi Keith,
Thanks for the reply, unfortunately it didn't work.
This did: ../ancestor::randomList[1][@listItemPrefix='pf01']
