If you go to insert, comment (alt, ctrl, m) . YBryon
Thanks again Clay. I find it hard to use the help when you dont know the proper terminology to search on. I will do some reading.
Bryon
Thanks Clay.I added the date_time() into the insert statement.
insert("[".username.()." ".time_date(est)."]:");
Do you have any advice on ridding the time from the output?
Thanks again,
Chris
