cross reference fails in prod
Ok folks,
I need help with a head-scratcher.
In my FOSI on Arbortext 6.0 m090, I generate a link to the title wrapper of
a generated table when conditions are Just Right. In a recent update to my
FOSI I changed from an older link tag we are deprecating to a newer one.
This all works just dandy in DEV but in PROD (which should be the same), I
am not getting a link.
During the update I made changes to the DTD (needed a new link_type on the
newer link element) and, of course, to the stylesheet so the FOSI called in
the new link element, not the older one.
If I use my DEV Editor instance and publish to my DEV PE instance. It works.
If I use my PROD Editor instance and publish to my PROD PE instance. It
fails.
If I use my PROD Editor instance and publish to my DEV PE instance. It
works.
If I use my DEV Editor instance and publish to my PROD PE instance. It
fails.
I have rebooted the PROD server.
What the heck am I not thinking about that maybe I need to change?
I have DIFed the FOSIs, DTDs, re-re-reposted both, reloaded processes
(f=init), restarted Tomcat, and, as I said, rebooted the whole PROD server.
Gah! It's killing me.
Code samples ...
<generated_table_title_wrapper id="myspeciallinktype">
<link id="myspeciallinktype" link_type="number_title"<br"/>target_type="generated_table" />
That last, by the way, is savetexted into a variable that is used later.
Again ... it all works as designed/expected in DEV.
I was really hoping that typing this all up would clear some age-induced
cobweb from my brain, but ... no go.
Any thoughts?
P.S. My PTC notifications from today included the FOSI change in status
information. For what it's worth.
Paul Nagai
fails.
works.
fails.
Code samples ...
Any thoughts?
Paul Nagai
