custom Javascript issues after upgrading from 5.3 to 6.0
ptc-4765794
I've currently upgraded from Arbortext version 5.3 to Arbortext 6.0 M100 and I'm having some problems with porting over our custom javascript/ACL.
One of these customizations is a simple function run when the document is first loaded that checks a couple attributes of the root note:
var actDoc = Application.activeDocument;
var docRoot = actDoc.getDocumentElement();
var rootName = " + docRoot.getTagName();
Right now, docRoot is returning null which breaks the getTagName() call. Other exceptions in some of our other custom ACL also say:
Wrapped com.arbortext.epic.AclException: [A12653] The "detail" command is illegal for a text file.
All our custom code is running on 5.3 without hiccup. Are there any caveats/details I need to know about with custom javascript/ACL when upgrading from such an old version? I know Arbortext 5.3 used Rhino as a Javascript interpreter, did anything change there in the updaets maybe? I'm really lost here and would appreciate any input.
0 REPLIES 0
