null character not displaying
aleslie
I am building an ascii data stream and writing it out to a text file.
Each line of text needs to be terminated with the null character which I am appending to within the ACL via :
text_line=string . chr(0);
When I open the text file in Notepad++, and view symbols it is not displaying the NUL symbol; Other ascii symbols appear ok.
Am I using the correct ACL syntax ? Do I need to provide an extra parameter when writing out to the file ?
Andy
bibach
(To:aleslie)
On Tue, Jun 29, 2010 at 5:43 AM, Andy Leslie
Try building your string like this:
text_line = pack("a*x", string)
Also, make sure you include a "b" in the string for the "access"
parameter to the open() function and use the write() function to write
the data to the file.
-Brandon 🙂
