I built a part within my main assembly. I then took this part along with others and moved it to a subassembly. Inside the subassembly, i created a slider conection. It is free to move within the subassembly but when I go back in to the main assembly, it will not. The message i receive is "You may not drag a model belonging to the ground body." Does anyone know how i can solve this problem?
welcome to this forum,
If you can move the part inside the in the sub assembly, then there is diffrent ground body in the sub assembly. So when you have that sub assembly inside the main, the part shoul move.
I think you may check for other connections which may left with other component that belong to groundbody.
else can share the model.
