Assembly Regenration Error
Himanshu
While regenrating assembly an error symbol with alphabet 'D' and cross over it occurs in status bar. What does it mean ?? How to resolve it ?
Thanks a lot.. 🙂
8 REPLIES 8
please attach a screenshot.
Martin Hanák
Himanshu
(To:MartinHanak)
please find attached snap. At the bottom corner an error is displyed (highlighted in red box). No error description is visible on status bar.
I am sorry I can't help you, because I have never see "crossed D" symbol in status bar.
See:
https://community.ptc.com/t5/Creo-Modeling-Questions/TBD-next-to-green-light/m-p/255578#372552
https://www.ptc.com/en/support/article?n=CS81624
Martin Hanák
Check article CS31615 about this.
CS31615
configuration option enable_implied_joints as no
Thanks a lot.. 🙂
If you got the answer, accept appropriate reply as solution
This article reolves my query. Thanks
TomU
(To:Himanshu)
It means "Disconnected" and it will appear where there is some problem with the mechanism constraints.
