I've seen the "composite drawing" thing while working at two, maybe threecompanies, frankly I think it clearly shows the stupidity of the person who started the practice, and the foolishiness of the company to continue it. I've seen a lot of cases where people who are "entrenched" in a company do this stuff just to do as he pleases or to exert his influence.
Far too many companies get stuck in repeating the same foolish practices forever, apparently thinking if it was done previously, it has to, or shouldbe continued. Or, if someone provided instruction to do it that way, it's better to blindly continue doing it that way than toengage the brain.
I gotta say his response looks to be following the PHD method of slinging BS; Piled Higher & Deeper. Nothing about what he talks about makes sense. Our Tool Design department uses that method and even they admit the only reason is to make it easier for vendors to keep components together. Everything has the same drawing number, so they know everything goes together (12345-1, 12345-2, 12345-3, etc.) Not the best reason but they don’t make the attempt to justify it with some sort of ridiculous revision control argument.
In the end it’s your decision. If he’s a contractor, he does what you tell him to do. No discussion, no argument, no reasoning it out.
In Reply to Anthony DelNegro, P.E.:
So... A heated discussion it becomes... Just so you know, we are a small company with only 2 seats of Creo. We don't have a PDM system or any other means of managing files.
I asked my contractor why he uses multi-sheet drawing and what he feels are the pros. Here's what I got back. I don't really agree. I think the hassle they can cause would overcome any benefits gained. Also he mentions revision control, but I simply have a parameter in each part that automatically updates the assembly drawing, so I'm not really sure why he thinks reckon control is so much easier in multi-sheet drawings.
