I need to add the below relations to the assembly/part if they are missing using model check. Could anyone please guide me step by step how i could do that:-
For part :- PTC_COMMON_NAME=rel_model_name+".PRT"
For Assembly :- PTC_COMMON_NAME=rel_model_name+".ASM"
Set RELATION_MISS as E in respective check file.
Add PRT_RELATION PTC_COMMON_NAME=rel_model_name+".PRT" in respective start file
Is PTC planning to add post regeneration relations to be updated by ModelCHECK?
