I am needing to fine out which version of ProE was used to create a file, be it a Part model, and assembly, or a drawing. Can you tell me how to find this out?
Any help is appreciated!
Gerald,
You can usually open the file in a text editor and the header portion will list the version of the sofware used to create the file. It will look something like this:
Erik
Gerald,
Erik
Thanks Eric. This helps me. Have a great day!
