ProMdlLoad
Ketan_Lalcheta
ProMdlLoad
Hello
If i use API ProMdlLoad() to open assembly in Creo, is it necessary that all parts and subassemblies are available into directory?
If yes, is there a way to fetch tree structure of assembly (Name of parts and sub assemblies) provided only only assembly file is available with me.
Thanks and Regards
Ketan
Its the same as you open in manually in Creo. So you need to be able to loade the parts / subassemblies from the current Directory (Working Directory) or from the search path order.
So it should be possible to load the model since WF 5.0 if you have the config value of regen_failure_handling on no_resolve_mode. So he loads the assembly with failures on the Component KE's. After that you should be able to readout the first level of dependencies, or the first level of component features that are build in.
I haven't checked that, but I think I have done that in the past.
Br,
Eike
