I have been using a threaded shaft with RH and LH threads. The design is provided with 2 nuts, each with LH and RH threads. The rotation of the shaft generates an +ve motion in one nut and -ve motion in the other thread. The modeling is done through slot and point mechaninsm with helical sketch (RH and LH respectively),
Looking for better and simplistic ways to simulate this motion in Creo Parametric.
