Hello Community,
I'm having the problem with BOM Tables. How can I sort BOM table in the assembly drawing Based on the Name or the Quantity of the component or the type of Materials?
Sundar Dannana
select table tab > repeat region
menu appears > sort regions
select the region you wish to sort
menu appears, select how you would like to proceed
suggest to select show to see how your table is currently configured.
