I'm trying to build a rectangular (wheeled) frame assembly with an enclosure atop. The frame is built of T-profile struts connected to each other with bolts and brackets. I would like to know the following:
Any input is much appreciated. Thank you.
You could have a look at this recent discussion.
Similar situation to what you're trying to do, doesn't require advanced assembly module. I've used this technique for support frames made out of extruded aluminum struts (80/20, Rexroth, Misumi) and it's been a really good time-saver.
As you suspect, it takes a bit more work in the beginning, but when you need to make changes, having everything determined by the "master" assembly saves a huge amount of time.
