I would like to add "units" to my tree columns in my assembly.
Does not appear to be an option.
I'd like to see what is using "IPS" and what is using "creo parametric default" from a birdseye view.
When I get my assembly calculated weight, if there are mixed units the results are way off.
If there is another way...?
4.0 m020.
Wayne
That would be a nice feature to be able to add units as a column to the feature tree. The system knows the units, so it should be able to display it.
My concern is what level of 'units' do you want displayed? I think the units of measure MKS, or IPS may be too much and non-relevant to the feature tree. However, MM or IN may be sufficient.
I think this has been asked for in the past.
