importing Pro-E in Creo
SOLVED
Newbie
I opened a pro-E file in Creo3 but the names of all the parts are displayed obscuring the assembly.  Everything appears to be in a single layer and none of the annotation functions seem to allow me to remove/erase the text.  I'd appreciate any ideas to remove the text...
Thanks j
1 ACCEPTED SOLUTION
Re: importing Pro-E in Creo
Yes! that was it!  Thank you all very much.
7 REPLIES 7
please attach a picture of Creo window showing the problem.
MH
Martin Hanák
Sorry for the delay, finally got a picture of the problem.
I resamples the pic down to 500K, I hope that's acceptable these days, let me know...2016RobotAsyTextOverwrite.JPG
You might try the Print Scrn button to capture the whole screen or Alt-Print Scrn to capture the active window. If you are on a laptop it may require a function button as well. On the Dell I have it is Fn-Print Scrn and Alt-Fn_Print Scrn to do the same. Faster, smaller image and not moire limited; pixel perfect. Paste into MS Paint or your favorite image editor to crop out anything that isn't good to be included.
I think under the view Menu is a pull-down that controls display of ordinary datum tags; they can also be selected, put on a layer, and blanked. The control has a picture of the datum with a little letter next to it. The regular datum visibility control has only the datum pictured.
You are welcome.  If you would, please mark this thread as answered.
No doubt the correct answer.
