Is there a way to create a tracker item of type "Document" via the REST API? I have 10,000 documents to upload along with some meta-data and am looking for a programmatic solution.
PTC Support has indicated that there are no APIs to create tracker items of the Document type. I am hacking up an extension right now to see if I can do it myself.
Hi @rattmice
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
