CodeBeamer: Adjustment of test step field permissions not possible
TD_10768648
7-Bedrock
We're currently struggling with a test case tracker configuration in CodeBeamer 22.04-SP7, where we cannot seem to change the permissions of the test step table field (see screenshot, no adjustments possible, controls greyed out/deactivated)
bee67e57-ac9f-4596-a15f-dc850ee7b66f.jpg.
As a result, only project admins may read/write the correpsonding field but no regular users. As we want to avoid giving all users admin priviliges, is there maybe a way to get this working? Other fields of the same tracker may be modified as usual - this only applies to the test step field.
Thanks in advance.
Thanks for the reply, we found an alternative solution that didn't require modifying configuration files. It seems that we've had a change in our users that might have led to this issue to occur in the first place. Nevertheless, creating a tracker from scratch has resolved it for us and we're able to change permissions now.
gkosa
(To:TD_10768648)
Dear @TD_10768648 ,
I believe the following article will answer the above question: https://www.ptc.com/en/support/article/CS414756
Let me know if you need additional support.
Gabor
