I am working on deriving the default output for a choice field in our project, based on other two choice lists and on conditions that depend on fields with 4 and 5 choices. I have implemented the probable conditions as shown below, but currently I am only able to get the result for a single condition. Could you please help me obtain the output values for all the possible conditions or suggest the correct expression to handle these cases.
These three lists are used together to assess the overall risk.
Impact Rating (choiceList[2]):
ID 1: Severe
ID 2: High
ID 3: Medium
ID 4: Negligible
Feasibility Rating (choiceList[3]):
ID 1: Very Low
ID 2: Low
ID 3: Medium
ID 4: High
Risk Level (choiceList[4]):
ID 1: L1
ID 2: L2
ID 3: L3
ID 4: L4
ID 5: L5
This is the expression i am trying in computed as box in risk level choice list
List(choiceList[4]_$option[
(choiceList[2][0].id == 1 && choiceList[3][0].id == 4) ? 5 :
((choiceList[2][0].id == 1 && choiceList[3][0].id == 3) ||
(choiceList[2][0].id == 2 && choiceList[3][0].id == 4)) ? 4 :
((choiceList[2][0].id == 1 && choiceList[3][0].id == 2) ||
(choiceList[2][0].id == 2 && choiceList[3][0].id == 3) ||
(choiceList[2][0].id == 3 && choiceList[3][0].id == 4)) ? 3 :
((choiceList[2][0].id == 1 && choiceList[3][0].id == 1) ||
(choiceList[2][0].id == 2 && choiceList[3][0].id == 2) ||
(choiceList[2][0].id == 3 && (choiceList[3][0].id == 2 || choiceList[3][0].id == 3))) ? 2 :1])
please try the following computed formula:
List(
List(
List(0,0,0,0,0),
List(0,2,3,4,5),
List(0,1,2,3,4),
List(0,1,2,2,3),
List(0,1,1,1,1))
[choiceList[2][0].id]
[choiceList[3][0].id]
Istvan
List(
List(
List(0,0,0,0,0),
List(0,2,3,4,5),
List(0,1,2,3,4),
List(0,1,2,2,3),
List(0,1,1,1,1))
Istvan
I have tried the computed formula you provided and it worked.
Thank you for your reply.
