Codebeamer ASPICE template.
Chokchai
6-Contributor
Hi, As Codebeamer provided standard template for ISO-26262 & ASPICE. Is it possible to get only ASPICE template which is not concern with Safety in ISO-26262? Thank you.
Hi @Chokchai,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. Like:
  1. Your current setup or configuration with Codebeamer.
  2. Any challenges or issues you are facing with the current template.
  3. The intended use case for the ASPICE template.
  4. The version of Codebeamer you are using.
It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team
