Computed Logic for ASIL and CAL fileds
Rubiya
I want Computed Logic for Test case Tracker to populated ASIL & CAL filed values with " Verifies" Filed which linked to 12 requirements trackers
If I select Verifies item, my Test case tracker ASIL / CAL values should automatically generate based on its requirement ASIL / CAL values
Safety Requirement Trackers have ASIL Field (4 Trackers)
Security Requirement Trackers have CAL Filed (4 Trackers)
Now in my Test case if I select Verifies item of any requirement my ASIL values should automatically populated
JosephM_SAI
(To:Rubiya)
A few Computed Expressions & potentially some Shared Fields should make this possible!
So first to determine if we need shared fields: if the Label of the ASIL Fields in all of the Safety Requirement Trackers are the same, and the same for the CAL Fields in the Security Requirement Trackers, then we can simply use that common Label to reference the field in the Test Case tracker. Otherwise - if the labels for the field representing the same value in say two Safety Requirement Trackers are different for example, then we will need to create a Shared Field to allow the Test Case tracker to easily obtain the value no matter the label.
Of course if the different fields across trackers are different types, that may require additional logic to account for this in your expressions.
In this case, I simply created 4 trackers - two Safety Requirement with ASIL Fields and 2 Security Requirement with CAL Fields - but with different labels, so requiring a Shared Field:
ASIL Fields in the two Safety Requirements
CAL Field in Physical Security Requirement
CAL Field in Digital Security Requirement
Customizing the Test Case tracker is next! For the ones not requiring a shared field, they'd look like so:
Verifies[0]['ASIL Field']
where ASIL Field is the label of the upstream tracker item fields.
Where a Shared Field is needed, it's a slight change to use the sharedField function instead:
sharedField("CALField", Verifies[0])
where CALField is the Shared Field Name.
Of course if you need to support multiple upstream requirements, you'd use some list-functions such as a Projection and any additionally needed logic, such as summing up all the values for example:
sum(Verifies.{upstream | sharedField("CommonField", upstream)})
An example of the above fields (and an additional common field) setup looks like so:
JosephM_SAI_3-1741614546726.png Test Case with no Verifies:
both ASIL & CAL fields are hidden with the Common Field without a value
JosephM_SAI_4-1741614620618.png Test case with a Safety Requirement upstream:
ASIL Field visible & populated
Test Case with a Security Requirement upstream:
CAL Field visible & populated
If you additionally desire to hide the unused fields, you can of course use another computed expression for the Hide If value:
empty Verifies || contains(Verifies[0].tracker.name, "Security")
and make this as complex or as simple as needed.
Hopefully this is enough to get you started, feel free to reply if there is anything I missed, and good luck!
JosephM_SAI
(To:Rubiya)
Rubiya
(To:JosephM_SAI)
Hi @JosephM_SAI ,
I have gives the Computed Logics as above , iam able get the Result but including the Option id and other property detials like below : ASIL - QM(C) i dont want the other details
Current logic iam using Subjects >> Verifies
Choice list [4[ >> CAL
JosephM_SAI
(To:Rubiya)
Yup that's returning the full option - you can get the `.name` of those, so this should work for you:
subjects[0].ASIL[0].name
and it gracefully evaluates to nothing if the ASIL field for the subject has no chosen value.
If this is a multiple choice list and you want all of their names, that'd involve a projection at minimum:
join(subjects[0].ASIL.{chosen | chosen.name}.toArray(), '
 to generate
A
B
 given an upstream requirements with both A and B options chosen.
Hello @Rubiya,
It looks like you have a response from a community member. If it helped you solve your question please mark the  reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
