Different SSH server
JC_5247497
Q1: Inside the Git SSH documentation (https://codebeamer.com/cb/wiki/25661#section-SSH+Access), it says that an SSH server called OpenSSH should be installed on the server on which CB is running.
My Question is: can I use a different SSH server, such as Bitvise, and expect the same behaviour? Is there any more documentation about SSH configuration?
Q2: In the Generating SSH Keys section, it is written that we need a key pair. However there is a large number of configuration to set when generating a key pair e.g:
ssh-keygen -t rsa -b 4096 -C "dev@company.com" -f ~/.ssh/id_ed25519 -N ""
Any hints you could give me?
Hi @JC_5247497,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
