Display document image in tracker item description
eazzarito
Hello everyone,
Is it possible to display an image present in the documents tabs within a description of tracker item? I can add the link option to the image but not display.
Thanks to everyone.
Hi @eazzarito
It is possible. Be sure to use the upload file option or copy and paste the image directly into the tracker description. This should display the image when in the documents tab.
Brian Kampling - Source Allies
Brian Kampling | Software / Systems Engineering Consultant - Source Allies
Hi @eazzarito
I think the question was more about Pictures from "Documents".
For example, this markup...
...renders a picture stored under Documents tab.
Hi @eazzarito,
Anurag
