Escalation feature - problem
RB_10908682
Hi!
I have a problem related to escalation module in CB.
I have created the rules for escalation in one of my trackers but haven't added specific rules for preventing triggering of some cases. Therefore I have accidentally created escalation for items that are OK from the process perspective. I need to erase this escalations for those items - how to do that?
Hi @RB_10908682,
an Escalation Rule is a tracker-level object that applies to the tracker itself and not to the items individually.
This means that the Escalation Schedule of a particular Work Item cannot be updated (or even removed) directly.
The best way to resolve your issue is to create a new Escalation Rule with the correct conditions and then remove the incorrect one.
Best regards,
Istvan
Hi @RB_10908682,
Best regards,
Istvan
RB_10908682
(To:Istvan_Molnar)
Thanks for quick answer!
That solution worked as I figured it out in February few days after the issue : )
So we can generally assume, that proposed solution is good and cut-to-the-chase, thank you
