based on https://codebeamer.com/cb/wiki/1563473 and the example there, I try to export more than just comment (at.description).
Mainly, I look for the template code to get the user who created the comment, but I'd appreciate a (link to) the full structure definition much more.
So far I tried ( <jt:forEach items="${item.attachments}" var="at">${at.id}</jt:forEach>)
at.createdBy (gives me an empty cell)
at.name (filename of the attachment)
at.createdAt (two comma seperated numbers... any hints?)
at.id (not sure which id I get her, I guess the comment's id)
at.version (seems like the version of the comment)
at.comment (mostly empty. Once I got the text "description" which is nowhere in the item. It was only in a comment which was edited and had version=2)
Hello @Labisch, please try the attached template, hope this answers your question.
The following attributes are exported:
