Excel custom export template for Issue tracker
JN_10875910
2-Explorer
I'm trying to customize an Excel template to export the different fields of my Issue tracker (see issue_tracker_fields.png for the fields).
The "basic" template from codeBeamer does what I would like to do for the exported data but I would like to customize its style, for both single and multi row options (enabled through the GUI).
  • Exported Issue tracker using default codeBeamer template with multi-rows enabled: export_issue_tracker_default_template_multirows.xlsx
  • Exported Issue tracker using default codeBeamer template without multi-rows enabled: export_issue_tracker_default_template_singlerow.xlsx
  • My custom template: issue_tracker_custom_template.xlsx
  • Actual export results: export_issue_tracker_custom_template.xlsx
Note that the multi choice fields are only: "Owner(s) and "codeBeamer item(s)"
Could you please help me to correct my template to achieve similar results?
If you have access to the default codeBeamer export template file, that could also help!
Thanks a lot in advance,
Jonathan
(codeBeamer 21.09-SP5)
Hi @JN_10875910
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
