Github Enterprise Interface for Codebeamer
FT_10908593
We have the advanced license of Codebeamer ALM and know that there is an interface available to connect Github with Codebeamer.
Is the interface only available through the regular cloud Github or is it also possible to combine Github Enterprise with our Codebeamer environment?
Thank you for your time.
 We do not have a Codebeamer Support Community yet. You can contact the Codebeamer TechSupport team using the eSupport portal as well.: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Andra
This topic has been moved from the "Codebeamer Ideas" to the "Codebeamer" forum due to its non-idea nature and in order to receive the visibility needed.
Catalina
PTC Community Moderator
PTC
Survey Now Live!
Codebeamer Community: we're listening.
Add your voice in our short CSAT survey!
